Change retention for a specific JobID using REST API or Qscripts
  • February 23, 2022
  • 189 views
Forum|alt.badge.img+9
We need to change retention for multiple jobs. adding number of days to the existing retention.
Is there anyway to change retention for a sepecific JobID using REST API or Qscripts ?
Didn’t find anything in CV documentation.
Best answer by Hyder
This does it via qoperation
https://documentation.commvault.com/11.24/expert/11409_qoperation_jobretention.html
Hyder
  • February 23, 2022
  • February 23, 2022
Thanks Hyder.
Will check it.
I’m looking for a way to add n number of days to the existing retention. not change it by date.
