Changing Index node for Commser
  • Nov 13, 2026 7:45 PM UTC
  • 2 views
To reduce the CPU load on the CommServe server, I would like to migrate the Download role to a separate VM.
Since it is not possible to configure multiple nodes for this indexing configuration, I assume that the data needs to be migrated manually. Is that correct?
What would be the recommended best practice for performing this migration?
I have already provisioned a new VM and installed the Indexing package on it. Could you please advise on the next steps required to complete the migration, including how to safely transfer the existing indexing data and ensure that everything continues to function correctly?
We are on 11.40.82 version of commvault
Thank you in advance for your advice.
Hi ​@Egor Skepko
Can you clarify a bit more on what you’re trying to achieve here? I don’t want to make assumptions.
Not sure what you mean by the “Download Role”
But if this is just that you want to migrate the index server role+indexing details out of the commserve, then you can refer to the below community post, when you run the workflow, there is an option to “copy index”
Index Server migration to another Node (different Server) | Community
Abdu
