Changing Throughput from GB/hr to MB/s
  • March 21, 2023
  • 207 views
Forum|alt.badge.img+5
Hi all,
is there a way to change the the Unit for the “Current Throughput” in the Job Controller from GB/hr to MB/s?
kind regards
Joerg for ADN
Best answer by Chris Hollis
Hi @ADN GMBH
Found this key: https://documentation.commvault.com/additionalsetting/details?name=%22bEnableThroughPutInMbps%22&id=8374
Use this setting to control whether the Throughput column (Average/Current) in the Job Controller and Job Detail dialog boxes show values in GB (value = false) or Mbps (value = true).
Add this to the Commserve (right click Commserve > Properties > Additional Settings).
Chris Hollis
  • March 22, 2023
Hi @ADN GMBH
  • March 22, 2023
Thank you for the Information, that what i was looking for.
