Cleaning Tape not automatically used
  • January 10, 2025
  • 56 views
Forum|alt.badge.img+13
we have an Oracle tape library and sometimes i must clean the drives. I must do that over the web console from the library. Is it not possible that commvault does it automatically when a cleaning is needed?
Thanks and regards
Dennis
Hello ​@Dennis
The following goes over the auto cleaning feature:
https://documentation.commvault.com/2024e/expert/drive_cleaning_overview.html
Please advise if it answers your questions and tackles your issue.
Kind regards​​​​​​​
Albert Williams
  • January 13, 2025
Thanks a lot.
This are my options i set:
But i can’t find an option where i can enable automatically drive cleaning…...
