Client Side Encryption
  • June 22, 2023
  • 126 views
We want to enable Client Side Encryption on Commvault. Does we need to install a Commvault Agent on the Client ?
Best Regards!
Best answer by Rajiv
Hello @Celine
Please go through the documentation: https://documentation.commvault.com/2022e/expert/7874_data_encryption_online_help.html#client-computer-properties-encryption
You can select the options suitable as per your requirement.
Best,
Rajiv Singal
Forum|alt.badge.img+18
  • June 22, 2023
What agents do you have installed on the client currently?  There is no separate agent for encryption.
  • June 26, 2023
Actually, no backup agent is installed on the Client. We use Agentless Backup and Recovery
  • June 29, 2023
Rajiv
  • June 29, 2023
Hello @Celine
Best,
Rajiv Singal
