Client upgrade successful from console but not reflecting on client OS
  • May 4, 2022
  • 8 replies
  • 509 views
Hi guys,
Recently, we upgraded our CommCell environment, from one of the clients, the upgrade passed successfully, on the CommCell console, the new version is showed up, but on the client side, when checking the commvault services status, we found out that it’s the old version that is still showed up comparing to the other clients.
We tried restarting services, but, the issue remained.
Any suggestion to clear this issue ? Is there some sort of cache on the clients to be cleared, or anything else ?
Regards.
Best answer by christopherlecky
Have you tried deconfiguring and reconfiguring the client?
Aplynx
  • May 4, 2022
Can you see what the updateinfo.log file says was the last installed update on the client? Should be towards the bottom.
Thanks, @Aplynx for your feedback, will check again the logs.
@Commvault Engineer , following up on this one.  anything turn up to help you solve this one?
Unfortunately, we still didn’t get the chance to be able to check the logs, due to customer unavailability.
Will update on this once we’ve something concrete.
Thanks again for your support!
Always!
We’ll be here when you’re ready 🤓
christopherlecky
Challenger
Forum|alt.badge.img+21
Always!
Thanks a lot Mike :)
Thanks, @christopherlecky, for the suggestion, will try it out !
