Commserv Anomaly Alert Type: Operation - Admin Alert
  • August 27, 2021
  • 11 replies
  • 1145 views
We get many mails with anomaly notification, like this:
We do not see any errors or events regarding this alert. Does anybody know why this alert was created?
Best answer by DMCVault
This is showing a backup event being triggered more than it normally does.  You would need to investigate the job(s) to see what happened during the backup.
For example are you running backups more frequently than usual, where there is a sudden increase in this event getting triggered?
MichaelCapon
Hi @ThomasG ,
The CommServe Anomaly Alert is enabled by Default. - You can find out more detail on the pre-defined alerts here: https://documentation.commvault.com/commvault/v11_sp20/article?p=5199.htm#o131659
Best Regards,
Michael
  • August 27, 2021
Hi @MichaelCapon ,
Yes, I know, thank you. The question is now, what anomaly was the reason for this alert. We do not see the reason for it in details, we only see occurrence.
Thomas
MichaelCapon
Thanks @ThomasG ,
I suspect this will be sent due to one of the configuration conditions in the Alert.
Is there anything different about this Job (48064)? - Did it run for longer duration? or protect more/less VM’s than usual?
Do you get a link in that email alert to a WebConsole Report/Dashboard at all? - If so can you confirm what one it is please?
Michael
  • August 27, 2021
@ThomasG , have you had a chance to review @DMCVault ‘s question?
  • May 11, 2022
We started seeing this alarm after installing many Commvault SQL agents and enabled scheduled transaction logs backups. Before that we only ran AUX during the day and one incremental/full per day.
Anyone have an idea how we can override this particular “alert” for when many completed jobs has been running for certain clients/groups without disabling alerts for say when many jobs has failed.
@Mats , can you share a screenshot of the exact alert criteria you are receiving?
I’ll likely split this off into its own thread to better track a solution for you.
  • May 11, 2022
Hi Mike!
Sure no problem.
I didn’t realize SQL files could be anomalous, though I’ll defer to @DMCVault !
  • Certified Expert
  • June 28, 2022
Hi guys,
I have the exact same behaviour at a customer. Transaction Logs for SQL are running scheduled every 30 minutes since a few month, no issues or increase in jobs has been noticed.  There are still daily alerts about Anomaly in Occurrence.
Have you been able to find what can be causing these alerts? We cannot see anything strange and are considering excluding these SQL clients from the alert.
/Patrik
@Patrik , unless @DMCVault has anything toa dd, I would create a support case (and share the incident number here) so we can track it.
