Commserv on Linux
  • April 22, 2022
  • 245 views
I have seen a few comments on this subject but i still cannot find the linux commserv software.
I have used the download manager and here is the contents of the latest v11.25 Media kit, v11.26 is the same.
Should i be be seeing the Commserve module for linux also ???
Phil
Best answer by Orazan
You would need to apply for early access.   Everything will be explained in the registration process.
Hi @PhilC !  Welcome to our community!
The Linux Commserve is still in early access:
Adding @MFasulo who can advise accordingly.
  • April 26, 2022
Hi Mike,
Thanks for the reply, so is the linux commserve product not on General Release at this time ??
Thx,
Phil
Correct.
If you want to apply for Early Access, let us know.
  • April 27, 2022
Is there a chance of getting a copy to test it,  is there a process i need to follow.??  How does Commvault cover support ?? Is it the same or is there no support at this time ?/
Forum|alt.badge.img+18
  • April 27, 2022
