Commserve failover- Production Maintenance Failover/Failback issue
  • June 23, 2023
  • 237 views
Forum|alt.badge.img+5
Hello Team,
We are testing Commserve failover test using production maintenance, while performing the activity it’s getting an error.
Comparing the database and binaries version...    Failed
LiveSync and replication jobs are running properly as per schedule but every time failing in that step during failover.
Please advise.
Best answer by Anandha K
The DR instance version is differed from Prod. After the upgrade the failover and failback is working fine.
Thanks for your update.
  • June 23, 2023
what are the versions on each instance on production/DR nodes.
see general tab on Instance001 & Instance002 on both prod and DR nodes
  • June 24, 2023
