CommServe / MediaAgent IndexStore split
  • August 22, 2023
  • 76 views
Good day Community,
I have a customer with an All-in-one server CommServe/MediaAgent.
We want to split the MediaAgent in a second instance (Instance002). But the MediaAgent is also used to index Exchange Online backups. It therefore has the IndexStore component installed and has existing indexes.
Is there a procedure to migrate the MediaAgent AND IndexStore component? Probably a hardware refresh procedure for the IndexStore.
Thanks in advance for you help.
Best answer by Sebastien Merluzzi
Hi @Carl Brault ,
I think the best way would be to add an Index Server on Instance002:
https://documentation.commvault.com/2022e/essential/131954_creating_index_server.html
Then migrate from Index Server 01 to Index Server 02:
https://documentation.commvault.com/2022e/expert/93146_moving_index_directory_for_index_server.html
Sebastien
Hi @Carl Brault ,
Sebastien
  • August 22, 2023
Thanks much @Sebastien Merluzzi , I’ll try that!
