Communication problem after updating from SP28 to SP32 - need to change the hostname from a long one to a short one
  • October 31, 2025
  • 117 views
Hello CV Community!
I've had a similar problem in other environments before, but I didn't investigate further.
Currently, after upgrading from SP28 to SP32, a communication problem occurred in one environment for an OLVM backup.
The logs show entries like these:
vsbkp.log
20252 4f1c 10/30 13:13:59 1413471 CVClient() - File[Client.cpp], Line[105] netHostName[ABC.XYZ.com]: Warning, deprecated call to lookup client using net hostname. Please use shortname instead
20252 4f1c 10/30 13:13:59 1413471 NetMessage::verifyResponseHeader() - Error Code [10485792] returned - [Error: AppLookupClientWithHostName errorCode[1] message[Unable to lookup client with hostname. Please check if CS has duplicate clients with hostname[ABC.XYZ.com].].
20252 4f1c 10/30 13:13:59 1413471 ClientInterfaceNet::lookup() - Error: AppLookupClientWithHostName errorCode[1] message[Unable to lookup client with hostname. Please check if CS has duplicate clients with hostname[ABC.XYZ.com].].
20252 4f1c 10/30 13:13:59 1413471 SENDCOMPDCHANGE sendDirChange: failed to get media agent version information for [ABC.XYZ.com]
After changing the "long" FQDN hostname to a "short" one, the problem stopped. However, I'm wondering what's causing this. Has something changed since SP32 and the "long" hostname isn't supported and must be a "short" one or an IP address?
It's possible that in some environments, changing the hostname from a long name is not possible.
Thanks in advance!
Kind Regards,
Kamil
dude
Forum|alt.badge.img+20
  • Community All Star
  • October 31, 2025
Can you check if you have a duplicate client configured?
"Error: AppLookupClientWithHostName errorCode[1] message[Unable to lookup client with hostname. Please check if CS has duplicate clients with hostname[ABC.XYZ.com"
When looking at 11.32 hotfixes I see this which appears to relates to your issue
Duplicate VM client gets created when there are packages installed with short hostname on the VM.
If that is the case, I would run the Merge Client workflow to try to resolve the duplicate.
