Commvault 11.28 / 2022E cvCertTool help needed: How to delete a bad CSR ?
  • December 22, 2022
  • 205 views
RC23
Apprentice
We are running Commvault 11.28.32 / 2022E.
I would need some help with cvCertTool (cvCertTool.cmd) utility, I have generated a wrong CSR and I would like to delete it and create a new one.
Is there a way to do that “properly” ?
Do I have to enable the force-actions=true parameter in the properties file ?
Or do I have to create a new workspace, and then generate a new keypair, and CSR ?
Thank you in advance.
Regards
Best answer by Orazan
If  you input the wrong value or input in the CSR, you can just choose not to use that CSR and make a new one.  If the CSR is “bad” because of something from the keystore is bad, you would need to make a new keystore.  The CSR is not anything that is stored in the keystore, it is just terms added to to the keystore info to generate a cert.
Forum|alt.badge.img+18
  • December 22, 2022
