Commvault 11.44: How do I schedule a weekly Synthetic Full in a VMware Backup Plan?
  • Nov 15, 2026 9:50 AM UTC
  • 12 views
Hi everyone,
I’m running Commvault 11.44 and using a Backup Plan for VMware. I’d like to replace the automatic Synthetic Full schedule with a fixed schedule that runs at a specific day and time at the end of each week.
Can this be configured directly in the Backup Plan in Command Center? If it requires a separate Schedule Policy, what’s the supported way to replace the Plan’s automatic Synthetic Full schedule while keeping the existing incremental schedule and Aux Copy to DR in place?
If you’ve done this on 11.44, I’d appreciate the steps and which console you used.
Jean-Paul
  • Nov 15, 2026 10:28 PM UTC
Hi Jean-Paul,
This was a removed default in Command Center to simplify Sythetic Full management.
To manage the schedule you can either use the Commcell Console or the following additional setting:
https://documentation.commvault.com/additionalsetting/showsynthfullschedulesinserverplan-10824.html
The additional setting will add manual Synthetic Full scheduling to Command Center.
If you aren’t familiar with creating such a setting, you can check the following document.
https://documentation.commvault.com/11.44/software/adding_commcell_setting.html
Cheers,
Jace
Onno van den Berg
Forum|alt.badge.img+24
Hi everyone,
Jean-Paul
Just out of curiosity what's the need to schedule it to run on a fix schedule?
