Hi Team,
I was documenting about the feasibility of the Air Gaping on commvault, and found the picture below.
Can someone guide me where can I find and download the concerned workflows ?
Thanks in advance.
Hi Team,
Thanks in advance.
Best answer by DMCVault
Let me explain this a bit further though...
Air gapping is mostly architecture, with some software configuration. It first starts with isolating storage. For on premises setups, you would want to architect the solution wherein a secondary or tertiary copy of data is segmented/isolated from the production environment - often referred to as a “vault” environment, or “clean room”. This would typically require network configurations. Ideally the isolated storage can only communicate out to the production environment using Commvault encrypted tunnels. This can be direct one-way, or using a gateway in-between. Use Commvault network topologies to configure the rules for how the resources will communicate to one another.
Gapping is the process of shutting down the communication tunnel periodically. This can be done a few ways, and may require minor customization (and depends on requirements and architecture):
Let me know if you have questions.
