Commvault Diagrams library to create into Gliffy Confluence
Forum|alt.badge.img+5
Hi Team,
Do we have commvault diagrams library to import and use in gliffy confluence to create backup Estate Arch easily ?
I have very old infra arch diagram which was created years back , Now need to update the arch diagrams with commvault devices connectivity so I have Gliffy for Confluence using , if we have commvault defined images library to import will be greatly reduce my time on recreating the  Arch.
Best answer by Orazan
@Srikanth K - If you reach out to @Mike Struening directly he can assist you with the templates.
  • 630 replies
  • July 14, 2022
Good morning.  Would Visio templates work for you?
Forum|alt.badge.img+23
@Srikanth K , I have a link for the visio templates.  They are no longer supported and presented ‘as-is’.
If those will do, send me a pm and I’ll send you the link.
  • Byte
  • 13 replies
  • July 14, 2022
Thanks @Mike Struening ,
to import , I am allowed the below format. it will be great if you can share the visio any of the format
  • 630 replies
  • July 14, 2022
Already sent!
Thanks all 😎
Cookie policy
Cookie settings
