Commvault File data backup with HPE object storage using bucket
  • September 3, 2025
  • 106 views
Hello Team,
We are planning to implement Commvault backup of File system data (approx. 95 TB) and will use disk library of HPE object storage bucket.
This is on-premises backup.
Please advise any best practice to use in object backed target library.
  • How many buckets to create from object storage will use in Commvault library.
  • How many disk library to use (in each bucket to use single disk library or many buckets to use single library)
  • Any ways to configure Data reader & writers limitation
  • Shall we use Dedup, Compression & encryption feature from commvault to use object based target.
Thanks in advance.
  • September 11, 2025
Unfortunately the answer to all those is - it depends, and this post doesn't have much details. But, I’d suggest keeping things simple - you can change these down the line if you need to.
    • Single bucket should be fine unless the HPE device gets better performance writing to distinct buckets.
    • One should be OK
    • Yes, controls can be set at various levels - on the bucket, datapath, storage policy etc. You can find tune them as you go to maximize performance
    • Yes
