Commvault Manual installation Linux file system and Oracle agent
  • May 11, 2023
  • 1512 views
Hello Community,
Can someone point me to the Linux agent installation instruction.
Thank you.
Best answer by Collin Harper
Hello @Yolanda
You can refer to the below documentation.
Getting Started with the Linux File System Agent - https://documentation.commvault.com/2022e/expert/42628_getting_started_with_linux_file_system_agent.html
Thank you,
Collin
Hello @Yolanda
Thank you,
Collin
  • May 11, 2023
Hello CV Community.  I found install instructions.
Thank you.
