Commvault PostgreSQL Cluster: Automatic Master Node Selection After Failover
  • February 6, 2026
  • 7 replies
  • 174 views
We are experiencing a challenge with Commvault and PostgreSQL in a clustered environment and would like to ask if there is a supported or recommended approach.
Environment
  • PostgreSQL cluster with 1 Master and 3 Standby nodes
  • Automatic failover managed by Patroni
  • Commvault PostgreSQL agent is configured at the cluster level
Current Behavior
  • Commvault is able to detect failover events correctly.
  • However, when the Master role changes, Commvault does not automatically prioritize the new Master node for backups.
  • After a failover, we must manually move the new Master node to the first position in the cluster client configuration.
Is there:
  • A native Commvault feature, or
  • A supported best practice
that allows Commvault to automatically switch backup operations to the active PostgreSQL Master node after failover, without requiring manual reordering of cluster nodes?
CV_GK
  • February 10, 2026
Hi ​@Burak Yildiz
Please share CV and DB version details
  • February 10, 2026
Hi ​@CV_GK ,
CV version: 11.36.76
Postgre Version: 14
Thank you
CV_GK
  • February 12, 2026
Hi ​@Burak Yildiz
Can we please know reason for reordering? what behavior is seen if you don't reorder?
Are you using dump based or fs based backup?
CV_GK
  • February 13, 2026
Hi ​@Burak Yildiz
Full backups run on STANDBY nodes by default in the order of configuration and finally fall back to MASTER node if none of the STANDBY nodes are available. This is current expected behavior.
We have an option for log backups to run on MASTER node.
Can we know your ask here? Do you always want to run the full backup on MASTER only?
  • February 20, 2026
Hi ​@CV_GK ,
Yes we always use Master node for Log backups and want to run full backup on Master node as well.
Description: PostgreSQL Database: [~Function failed during execution. (ERROR_FUNCTION_FAILED.1627), Master and Standby roles could not be properly set (W32.1627)~] Data Backup Failed.
CV_GK
  • June 8, 2026
Hi ​@Burak Yildiz
I discussed with query with our Dev. Team, as per them :
By default master node is the last option to fall back if only all other standby nodes are down. We look for any available standby node in the order specified in the instance properties. That’s why after failover reordering of the nodes is needed.
If you always want to run backup only on master node, please create a CMR to add an option for it.
Can we close this post now?
CV_GK
  • June 15, 2026
Hi ​@Burak Yildiz
Can we close this query post now?
