commvault sql agent and SQL native bak backups copy-only together,
  • August 8, 2023
  • 84 views
Sysadmin is running Commvault SQL Agent backups, DBA is running SQL Native Copy-only backups.
Will this cause LSN issues?
Best answer by Scott Reynolds
@Ron
No that will be fine as long as the DBAs stick to copy-only backups as they do not affect the log sequencing of regular backups. Note that copy-only log backups do not truncate logs.
@Ron
  • August 11, 2023
Thanks, Im asking because every time the Copy-only backups is done seems like my commvault backups have issues.
@Ron  Are the tlog backups converting to full backups or having other issues like going pending/failing?
