Hello
I am planning to upgrade the CommServe from SP 11.36 to SP 11.40.
The CommServe and Web Server are installed on the same VM, running Windows Server 2022 with SQL Server 2022.
Is it sufficient to start the upgrade directly from the CommCell Console, or would you recommend using the Media Kit instead?
Also, are there any specific things I should pay close attention to during the upgrade process?
