Commvault Upgrade to SP 11.40
  • June 23, 2026
  • 46 views
Hello
I am planning to upgrade the CommServe from SP 11.36 to SP 11.40.
The CommServe and Web Server are installed on the same VM, running Windows Server 2022 with SQL Server 2022.
Is it sufficient to start the upgrade directly from the CommCell Console, or would you recommend using the Media Kit instead?
Also, are there any specific things I should pay close attention to during the upgrade process?
Sureshkumar S
Hi ​@Egor Skepko,
Good day!
Update your software cache with SP40
On the instance001 on the commserv do it from media kit.
All other machines you can do a push install.
Note : Make sure you have all prechecks completed (DR backup/Disable scheduler etc...)
Upgrade sequence : commserv → webserver → Media agents → client
Sureshkumar S
  • Challenger
  • June 30, 2026
@Sureshkumar S
Thank i wil do it, our webserver is on same client as commserver so its wil upgraded through media kit. In media Kit incl. sql upgrade?
