Commvault virtualize-me VMware for linux machine
  • July 13, 2023
  • 7 replies
  • 193 views
Dears all,
I am trying to performe migration of physical linux machine to VMware virtual machine using the commvault. I am using the Virtualize me options, and for this operation i’ve enabled 1-touch recovery in the source machine and a sucessfully backup.
For some reason after a successfully restore of System state backup, this error appears in the screen.
but these file initrd.img is a content of the defaultBackupSet
I’m using commvault version 11.24 and the machine use ubuntu 18 as operating system.
Please help me to solve this issue.
Rajiv
  • July 14, 2023
Hello @varsenia
Could you please try to take 2 more backups and re try the recovery? I have seen some scenarios where first backup gives such issues with Ubuntu.
Best,
Rajiv Singal
  • July 14, 2023
Hi @Rajiv
I made 2 more backups but i still having the same problems.
Rajiv
  • July 17, 2023
Hello @varsenia while on this screen, please press ALT+F2  and tail for the cvrestore.log: tail -100f /tmp/cvrestore.log
Best,
Rajiv Singal
  • July 17, 2023
I @Rajiv,
Thanks for the time,
I have solved the problem.
Rajiv
  • July 18, 2023
Hello @varsenia I am glad the issue has been resolved. Could you please share the resolution here with us for other’s references?
Best,
Rajiv Singal
  • July 19, 2023
Hi @Rajiv,
It is seems like the symbolic link initrd.img does not work properly after the restore of system state backup.
So before the backup i copy the initrd.img-kernel_version from /boot to / and performe a backup.
After that it work properly.
Rajiv
  • July 19, 2023
Hello @varsenia Thanks for the update! Yeah it could be ACL issues with the backup itself where symbolic links might not be backed with proper permissions however I am glad that the restore has worked for you!
Best,
Rajiv Singal
