Commvault WORM
  • May 31, 2022
  • 631 views
hi,
we have on AUX copy with WORM definition,
now we want to delete those jobs
can someone help?
Best answer by HolowEd
@liorkrispin
You will need to open a ticket as there is a procedure that needs to be followed in order to disable the Worm copy in order to allow you to delete the jobs.
  • May 31, 2022
@liorkrispin
