Commvault upgrade includes upgrade of Commserve Console, Media agents and Servers (VM and Physical). We have about 14 different sites and over 500 servers so I cannot complete upgrade of Commcell console in a day. Probably it will take about a month to complete upgrade across site. So my question is will the backup have any issues when the commcell console (11.24) is in an upgrade version and the media agent and servers are in lower version (11.16)
Commvult upgrade across site from 11SP16 to 11SP24
Best answer by MarkusBaumhardt
Hi Chitra,
confirming Onno’s statement that in-place upgrade from SP16 directly to FR24 is fully supported. However, you may want to ensure it will succeed without any issue in your individual case. For this I recommend opening a Support Incident, uploading the Commserve database (i.e. DR-Set) and ask for FR24 upgrade test of that database. Support will then test the upgrade for you in the lab and advise what needs to be changed before the upgrade if any issue is found. Just provide the following additional information to the ticket:
- Commvault release and patch level that is installed on your CommServe (SP16 with HotfixPack xx)
- CommServe SQL Server version and patch level (note that SQL Server might have to be upgraded separately before the Commvault upgrade)
OS in-place upgrades are depending on Microsoft support and do not affect Commvault. As a result, OS in-place upgrade is supported from Commvault side as long as it is supported by Microsoft.
However, in order to have a clean setup without keeping the configuration and update garbage of years of operation on the system, and to avoid separate SQL Server upgrade, I’d recommend setting up a new CommServe with a fresh Commvault CommServe installation. Use the “CommServe Upgrade with Hardware Refresh” procedure for this option as described in the online documentation at https://documentation.commvault.com/11.24/expert/2224_commserve_upgrade_with_hardware_refresh_overview.html
