Configure Secondary Copy to Tape with Primary one on Disk is Deduped
  • December 23, 2023
  • 253 views
Hi Vaulters,
We have all our Storage policies Primary copies being backed up to our main backup Disk Library while the data being Deduped.
We acquired a new Tape Library and wanted to use it as a storage for secondary copies, i.e., we want to create a secondary copy for each Storage Policy using the Tape Library.
Our main concern is the Deduplication, how the secondary copy to Tape handles the Deduplication on the Main disk Library ? Does the Dedupe cause any issue ?
Regards.
Best answer by Collin Harper
Hello @Commvault Engineer
Deduplication is “Copy Specific” and does not carry over across copies. Each Copy will need to be associated to a different DDB and unfortunately Deduplication to Tape is not supported. We can only write non-deduplicated data to tape.
Thank you,
Collin
  • December 26, 2023
Thank you,
Collin
Thanks, Colin, I already read somewhere that Dedup on Tape is not supported.
Just to confirm one more thing, does that mean, If we configure a secondary copy to tape from a Primary one which is stored on disk and has Dedup enabled, the copy will automatically reconstruct the blocks of that specific job copy, even if it is deduped on the primary one on disk ?
Scott Moseman
Forum|alt.badge.img+23
Yes.  The full data (non-deduplicated) will be ready from Primary and sent to the Secondary copy.
Scott
Scott
Thanks, @Scott Moseman for the confirmation :)
