Content settings in backupset / /* /. ?
  • June 5, 2023
  • 119 views
I would like to know what is the difference between configuring a backupset to collect the following content:
Which of the 3 options should backup the entire server?
What does each of these options collect?
Best answer by SparshGupta
Hi @Cintoteca
If you need to backup entire server, the content should simplay be “/”
  • / = Backup everything
  • /* = Backup everything at the root level. It will not backup nested files & folders
https://documentation.commvault.com/v11/essential/86709_wildcards_for_unix_file_system_subclients.html
Sparsh
SparshGupta
  • June 5, 2023
Hi @Cintoteca
Sparsh
