Could not get SIDB folders
  • January 20, 2022
  • 130 views
Forum|alt.badge.img+9
Question: is there a report that gives you the names of the clients that are running but have the error
Could not get SIDB folders  ?
right now I manually view the logs from the job
Best answer by Sebastien Merluzzi
Hi @gary mcneely ,
In Event Viewer, you should find/filter the error. make sure you display Computers. Below I filtered on “Failed to Mount”
Then top right click the two arrows and then select Save
Sebastien Merluzzi
@gary mcneely what if you ran a Job Summary report (to Excel) and filtered on the error code?
That should do it, or you could pivot the Job IDs and filter on the code there.
Hi @gary mcneely ,
Sebastien Merluzzi
