Could not start commserve after 2 days commserve shutdown
  • April 14, 2025
  • 124 views
I stopped commserve server last friday.
I started it recently,but it was in the following state:
( Time appears to be forwarded by 2 days 16 hours 52 minutes 4 seconds. )
 I click “Yes” button, but not start.
Next…. I enter “はい” and click “Yes” button , incorrect prompt error
Enter "Yes” and click “Yes” button same error.
I think this problem occurred display language
How to change Commvault Process manager language?
commvault 11.36.49 env.
Best answer by Pradeep
Hi ​@osakanataro,
Kindly follow below POA to fix the time change.
Press win+r  then type "regedit”, go to this location
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\Cvd
You will find "lastSystemStoredTime”. Update the Last Stored System Time with the current time which is Unix time format (You can take a backup of your registry) before making changes.
After that reset the time shifted back to 0 and try starting the services It should work.
  • April 14, 2025
Hi ​@osakanataro,
Emils
  • April 14, 2025
Hi ​@osakanataro
To update Process Manager to english, please follow these steps:
  1. Right-click on the Process Manager icon and select 'Properties'.
    • In the 'Shortcut' tab, find the 'Target' field and add the following arguments to force the language to English: -Duser.language=us -Duser.country=US
    • The edited 'Target' field should look similar to this: C:\commvault\jre\bin\javaw.exe -Duser.language=us -Duser.country=US -jar cv.jar yourcommserveFQDN 8401 -oemid=1
    • After making these changes, close and reopen the Process Manager using the modified shortcut.
URL: https://documentation.commvault.com/2024e/expert/configuring_language_for_stand_alone_commcell_console.html
Thank you
  • April 14, 2025
@Pradeep thanks, worked fine
@Emils it looks for java application Commcell console( cv.jar ).
I want to change for Commvault process manager( GxSplash.exe ).
