Create client group from Active directory group
  • September 7, 2022
  • 107 views
I would like to create a client group based on an windows AD computer group, is there an existing way of doing this.
If this is not possible and I have a dump of the AD group how can I script the creation or the addition of these computers to a Commvualt client group.
Best answer by Sebastien Merluzzi
@Norms
Also, you can check how to add using Command Line:
https://documentation.commvault.com/2022e/expert/4914_command_line_interface_client_computer_groups.html
@Norms
Have you checked “Automatic Association“ Groups, like the existing Infrastructure or Proxy Groups?
Sebastien
  • September 9, 2022
Thanks for the help, I am aware of the automatic group creation but I would need to be able to have the list of servers in the AD pulled by Commvault which does not seem possible. If I use the group creation template I will just have to pull the names of the servers from the AD
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • September 9, 2022
I have not found an opion in the gui either for this.
Guess you can only perform this by scripting.
Based on the assumption that your client names are equal to the computer object names in the AD you could retreive computer object names based on an AD group, pass these names in to a variable and use that variable in a qcommand:
https://documentation.commvault.com/2022e/expert/SetClientGroup.html
  • September 14, 2022
Thanks Jos,
That is also a simpler  method.
Jos Meijer
Your welcome 😃
