Critical event: Index Cache [exes_plan_Primary_26_Cache36] was taken offline because the free space [1714 MB] is less than the threshold [5120 MB]. Reporting MediaAgent: []
  • March 21, 2022
  • 140 views
I have received the following critical errors related to one of our clients, how can i solve?
Thks
Dario
Critical 279225   03/20/2022 16:10:28 MediaManager win-commserve 32:218 Index Cache [exes_plan_Copy-2_31_Cache43] was taken offline because the free space [1714 MB] is less than the threshold [5120 MB]. Reporting MediaAgent: []
Critical 279224   03/20/2022 16:10:28 MediaManager win-commserve 32:218 Index Cache [exes_plan_Copy-2_31_Cache42] was taken offline because the free space [1714 MB] is less than the threshold [5120 MB]. Reporting MediaAgent: []
Critical 279223   03/20/2022 16:10:28 MediaManager win-commserve 32:218
Best answer by Mike Struening
Sharing your solution:
I solved it by extending the disk assigned to deduplication.
@DarioV , looks like your Index Cache is nearly out of space.
Can you move it to a larger drive?
Instructions are found here:
https://documentation.commvault.com/11.25/expert/10730_changing_location_of_index_cache_directory_indexing_version_1_and_indexing_version_2_01.html
  • March 21, 2022
Hi Mike,
I don't understand I still have a lot of free space on the disco :
Are you sure this is the Media Agent in question for the alert?
I agree, you have PLENTY of free space, though I don’t see the Media agent specified in the alert.
Otherwise, if the alert *IS* for this MA it might be worth a support incident (and sharing the case number here for tracking).
