Critical Index Fragmentation - zero indexes > 50% Fragmented
  • January 10, 2023
  • 526 views
Ken_H
Challenger
Forum|alt.badge.img+18
My Web Console Health Report simultaneously shows a critical issue with Database Index Fragmentation and zero indexes with >50% Fragmentation.
Is this something I can fix or do I need top open a support ticket?
Thanks in advance for any help.
Ken
Best answer by Orazan
Good morning.   I would recommend that you run the suggested “DBMaintenance -recommended” command.  Here is the documentation on DBMaintenance.
https://documentation.commvault.com/2022e/expert/8690_performing_commserve_database_maintenance_using_dbmaintenance_utility_01.html
  • January 11, 2023
Ken_H
Challenger
  • Challenger
  • February 1, 2023
I ran the “DBMaintenance - recommended” as suggested and the next day the Health Report still showed a problem.  I just found some time to dig into this but the Database Index Fragmentation portion of the Health Report now shows as Good.
It was weird that CommVault reported a critical issue with zero critical indexes so I guess there’s a flaw somwhere in the details.  In any event, I’m back to normal now so I’ll mark the recommendation above as the solution.
Thanks for the help.
Ken
