CS Migration - v9 Clients
  • March 3, 2023
  • 165 views
christopherlecky
Challenger
Forum|alt.badge.img+21
Are there are any special considerations when doing a CS migration specifically to move older clients to another CS?
Best answer by Shaun Hunt
Hi @chrisknows
As a starter the following documentation will provide information on what is support from a migration matrix perspective: https://documentation.commvault.com/2022e/expert/5079_requirements_for_commcell_migration.html
If like you say the Commserves are on the same version this should be fully supported for v9 clients.
Forum|alt.badge.img+18
  • March 5, 2023
Are the two CommServes on the same version?
chrisknows
Challenger
  • Challenger
  • March 6, 2023
Yes they can be brought up to the same version
Shaun Hunt
  • March 20, 2023
Hi @chrisknows
Zubair Ahmed Sharief
Hello @christopherlecky
Very Old OS like 2003 or 2008 should be migrated to newer OS before migrating it to new CS. Newer Commvault versions may not support the obsolete OS versions. As a thumb rule, do not migrate anything the OS vendors don't support (EOL/EOS). The effect is profound in old version of OS. Newer version like 2012 are yet to show any symptoms of incompatibility.
chrisknows
Challenger
  • Challenger
  • March 22, 2023
@Zubair Ahmed Sharief in a perfect world that would be an option but typically when dealing with systems this old the standard attitude is dont touch them.
They are often in such a state that the technical debt surrounding them is exactly why they are running EOL.
Usually there isn’t much value in fighting this kind of battle.
