Custom package silent install hostname
  • February 1, 2022
  • 800 views
Hello
Is there a way to edit the install.xml file so that running a silent install for a custom package will make the hostname to be same as the clientname?
It looks like this in the xml file.
<clientEntity hostName="" clientName="" />
Hope you can help
Best answer by Alireza B
Hi. Don't believe we can automate this for every single silent install to make both names identical. You can obviously edit the XML and type the name you want for both names for a specific client.
https://documentation.commvault.com/11.24/assets/deployment/install/custom_package/sample_install_win.xml
Alireza B
  • February 1, 2022
  • February 2, 2022
The client name is generally derived from the hostname, so they should be similar out of the box? Hostname may contain the DNS suffix (FQDN) -  is that what you are trying to eliminate?
  • February 2, 2022
Yes we use FQDN and need to have both client and hostnames be identical.
