Customization of the Company view for customers
  • August 10, 2023
  • 74 views
Hello all,
is there a possibility to hide certain options in the Company view for the customers ? I would like to set this up so that the customers really only see the options that they should also use.
Regards
Thomas
Rajiv
  • August 10, 2023
Hello @thomas.S
You can check https://documentation.commvault.com/2022e/expert/8051_user_administration_and_security_overview.html and try to create roles and provide required permissions accordingly.
Best,
Rajiv Singal
Forum|alt.badge.img+9
  • August 10, 2023
  • August 10, 2023
  • Challenger
  • August 14, 2023
thanks for your feedback.
I rather meant the menu items when you look under Manage. Can this also be customized ? The customers need this view to be able to use the authcode.
Regards
Thomas
Onno van den Berg
Forum|alt.badge.img+24
You mean the specific options that you see under Manage → Company as the tiles directly under manage can be removed for company users by changing it in the Navigation preferences to be found under Manage → Customization → Navigation.
  • Challenger
  • August 15, 2023
Hello @Onno van den Berg,
I have attached a screenshot to show exactly what I meant. Here my question was if I can customize this page to hide for example the "External authentication" part for the customers ?
