CV - both java and console interfact are quite slow
We’re seeing slowness in CV when navigating the web interface.  The “Restore Options” panel takes about 20 seconds just to open, and then 20 seconds each time I change an option.  Is there any tuning options for the internal SQL instance, or something else we should be looking at?
This doesn’t affect the timing once the actual restore/backup is kicked off, just navigation is horribly slow.
Thank you - Chris
Interesting. Check out the EvMgrS.log and CVD.log file on the CommServe - see if it says anything about stored procedure timeouts or locks - there could be clues in there. Each stored procedure is measured in terms of performance and a log is printed if it exceeds the expected time.
Other than that, the obvious ones are CPU/Memory on the CommServe itself. Maybe check those out once you hit the restore dialog and see if there is a spike?
Thank you!  Here’s what we found, any guidance forward?
D:\Program Files\Commvault\ContentStore\Log Files>FINDSTR procedure EvMgrS_2025_03_06_10_06_45.log
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26857] user Id [8] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26857] user Id [9] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26857] user Id [13] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26859] user Id [8] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26859] user Id [9] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26859] user Id [13] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/04 21:32:52 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26859] user Id [10] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/05 21:32:53 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26868] user Id [9] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/05 21:32:53 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26868] user Id [8] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/05 21:32:53 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26868] user Id [10] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/05 21:32:53 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26868] user Id [13] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:02:21 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26872] user Id [9] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:02:21 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26872] user Id [10] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:02:21 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26872] user Id [13] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:02:22 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26872] user Id [20] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:14:29 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26874] user Id [9] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:14:29 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26874] user Id [10] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:14:29 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26874] user Id [13] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 08:14:29 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26874] user Id [20] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 10:01:23 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26876] user Id [8] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 10:01:23 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26876] user Id [9] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 10:01:23 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26876] user Id [10] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 10:01:23 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26876] user Id [13] pageStartId = [1] lastLiveFeedIdSend = 0
8584  964   03/06 10:01:23 ####### AlertLiveFeeds::fetchFeedItems() - No live Feed returned by stored procedure[Br_NTGetLiveFeedAlert] for Last Feed Id[26876] user Id [20] pageStartId = [1] lastLiveFeedIdSend = 0
Thank you - Chris
The only thing of note in the log are quite a few of these, which I’m unclear on.
Sunil
Forum|alt.badge.img+16
  • March 6, 2025
Hi ​@Chris Newman
How many data files do you have in the database you’re trying to restore?
Sunil-
Hi ​@Chris Newman
--We’re approaching 600 datafiles for some of our larger Oracle instances.
Sunil
  • March 7, 2025
Hi ​@Chris Newman
Apologies if I’ve missed something. But you mentioned SQL in your question. Is that SQL or Oracle?
Sunil-
Sorry, my MS SQL reference was to the internal MS SQL that CV users (or so we thought, spitballing here).  I haven’t nailed down slowness between checking Oracle vs MS SQL, but I can do that tomorrow.  Our databases with a large number of datafiles are Oracle; our MS SQL databases never have more than a handful at most.
Hey ​@Chris Newman - appreciate the detail. I think this might be one for support to look at - I think its a difficult one to solve here as it likely needs correlation with various logs to figure out the root cause.
Sunil
  • March 7, 2025
For the apples to apples comparison, please compare with Oracle database with small number of datafiles too. We can catch up tomorrow once you have some more info.
Sunil-
I’ve not found any difference in platform or datafiles, general slowness.  Most of the time seems to be spent from the gui home page, simply clicking on ‘Instances’ or ‘Databases’ takes 20 seconds to load.
