cvCertTool.cmd keysize options
  • July 14, 2022
  • 263 views
Forum|alt.badge.img+2
Hi there, I need to generate some .csrs from CommVault for our CA, who require RSA 4096 keys.
Java Keytool should accept a -keysize switch to define key length, but I can’t find how to set this value for cvCertTool.cmd.  Is this even possible?
Thanks.
Best answer by Orazan
Good afternoon.  I have reached out to one of our Server team SMEs who has advised me that currently the ability to set the desired value for CvCertTool.cmd is not supported.  A CMR is being created to add this function but until this feature has been added, you will have to use keytool to generate the CSR.
Please let me know if you have any questions.
Forum|alt.badge.img+18
  • July 14, 2022
Thanks for that Orazan.  I’ll look into doing it the keytool way.
