"CVGrpcCppSharpService" Service not starting
  • Jun 6, 2024 8:54 AM UTC
  • 7 replies
  • 833 views
Forum|alt.badge.img+5
Hello Commvault Community,
After an environment crash, one of the services won't turn on. What is this service and how critical is it?
No information in the documentation.
Michał
Forum|alt.badge.img+13
Hi Michal,
I found this in our internal knowledge base:
- The cvgrcappservice acts as a go between CS and webserver.
- There is a known issue internally for this service crashing when it starts from exe instead of DLL.
> For SP34, the issue is fixed using the batch script:WinServiceCreateCVGrpcCppSharpService 2.bat
Follow below steps:
[1] Stop all commvault services
[2] Close services.msc, taskmanager, commvault process manager
[3] Copy the bat file to the machine, open command prompt with administrator rights and navigate to the folder where the bat file is copied
[4] Run the command:
WinServiceCreateCVGrpcCppSharpService.bat
Example: ** **WinServiceCreateCVGrpcCppSharpService.bat Instance001 Commvault
[5] Start all commvault services and verify that "Commvault CVGrpcCppSharpService" service is started successfully
[6] Verify that you are able to login through the command center
> For SP36, the issue is already fixed.
Hope this helps and answers your question.
Markus
BTW: You need to open a ticket with our Support to get that script.
  • Jun 6, 2024 11:36 AM UTC
Thank you @MarkusBaumhardt ! So, I will create a support ticket.
Hi Michal, all,
please note we have an updated version of the script WinServiceCreateCVGrpcCppSharpService.bat available.
Please note that you still need to open a ticket with our Support to get the script.
  • Jul 17, 2024 9:05 AM UTC
Hi @MarkusBaumhardt I created a ticket. Problem have been solved.
Thank you.
Try making the services for a delayed start:
* CVGrpcCppSharpService(Instance001) → (120s),
* IIS (Windows World Wide Web Publishing) -> (180s),
* Tomcat → (240s)
That can do the trick.
  • Aug 6, 2024 11:42 AM UTC
how can i access the bat file?
Regards
Florian
EDIT:
Forget it … need a ticket
