ddboost aux copy with different retention period
  • February 15, 2024
  • 142 views
I need different retention perido for onsite/offsite copy using DD replication.
I will be using ddboost through media agent.
So to do this i just need to create ddboost replication pair on data domain and configure aux copy as usual on commvault?
Best answer by Chris Hollis
Hi @Sandy11
From my review of the documentation for this feature: https://documentation.commvault.com/2023e/essential/data_domain_boost_client.html yes, it appears to be business as usual. You can specify a storage policy, if that policy has two copies (onsite/offsite) and those copies have different retention rules, they will apply to the jobs as per your configuration preferences.
If you don't see this behaviour, please let me know.
Chris
Chris Hollis
  • February 16, 2024
Hi @Sandy11
Chris
  • March 14, 2024
Thank you. It works.
