Default Hardware VSS Provider Query
  • April 5, 2021
  • 629 views
Commvault V11
If you have installed Commvault hardware VSS provider and Netapp Ontap Provider at the same time, which Hardware VSS provider will Commvault use by default in an Intellisnap enabled backup?
Any answer to the question is appreciated.
Best answer by Sebastien Merluzzi
Dear @commvault
By default it will be using the Commvault Hardware VSS Provider. You can follow the steps below:
Configuring Backups Using Hardware VSS Provider from Storage Vendor https://documentation.commvault.com/commvault/v11_sp20/article?p=34220.htm#o34293
Bet Regards,
Seb
Dear @commvault
Bet Regards,
Seb
