Define a maintenance window
  • September 29, 2022
  • 162 views
Forum|alt.badge.img+8
I’m looking for a report in the form of calendar to compare all backup windows and define a maintenance window (CV upgrade, Os upgrade, hardware replacement), by SP should the best.
Does this type of report or functionality exists with CV ?
Thanks in advance,
Br,
Gilles
Hi Gilles - there is something close in the store for private metrics reporting -
it goes of off client/client group more that SP so not sure if it will fit your needs but worth a look.
https://cloud.commvault.com/webconsole/softwarestore/#!/135/660/11177
Hi @Gseibak ,
Thks for your feedback. I have seen this one but it’s not suitable. What I need will be :
