Delegating a Mailbox or a Folder Using Exchange Mailbox
  • October 19, 2021
  • 9 replies
  • 154 views
Kamil W
Certified Expert
Hello guys,
The client would like to perform delegation of some mailboxes from the admin level.
However, when we try the following procedure, we cannot see the 'Exchange' entry under 'Protection / Applications' section.
https://documentation.commvault.com/11.24/essential/107643_delegating_mailbox_or_folder_using_exchange_mailbox.html
The Exchange Mailbox agent is properly configured in the CommCell Console.
CommServe is running 11.25.x
My question is, is there any way to migrate Exchange Mailbox settings from CommCell Console to Command Center?
Rgds,
Kamil
Best answer by mszyba
Hello all,
It is look like bug.
Exchange application should be visable after add Exchange pseudo/virtual client via CommcellConsole.
But sometimes it isn’t occur.
Under Manage-->Customization--> Navigation we can customize view for CommCell admin and we can enable “Exchange” under Protect/Applications
Hi @Kamil W
It looks like the Guided Setup tasks for Exchange may not have been completed, which will enable that item in the menu.
Please take a look at Step 4: Configuring Solutions in the Command Center and complete the tasks for Exchange, then these options should be visible.
Stuart
  • October 19, 2021
Hello all,
Based on what @mszyba is saying, it looks like you already had Exchange configured in the CommCell Console, but couldn’t then see it in Command Center as well (until you went to Manage-->Customization--> Navigation to enable “Exchange” under Protect/Applications).
Is that correct?
Kamil W
Certified Expert
  • Certified Expert
  • October 21, 2021
Hi @Mike Struening ,
Yes, that’s correct.
I can also confirm that @mszyba ‘s solution did work.
Rgds,
Kamil
Sweet, thanks!
  • December 13, 2021
Do you know if it is possible to delegate permissions for deleted mailboxes (on the Exchange side)??
The client claims that there was such an option before and now it is not. In CommCell Console, mailboxes are available (but cannot be delegated there). I am sending you two screns in the attachment.
Thanks&Regards,
Kamil
Interesting.  Assuming you clicked the … and the option wasn’t there?
Here’s the delegate directions.  Note: last update was in 2020, so might be worth asking your customer how long ago they think they saw the option:
https://documentation.commvault.com/11.25/essential/127266_delegating_mailbox_or_folder.html
  • December 14, 2021
Hi @Mike Struening
This is the same Client from the beginning of this thread. At first he had no access to the view, but now there was a problem with the view of deleted mailboxes and the possibility of delegating permissions for them (the whole action has been happening recently - maybe a month period. BUT
Is delegation supported at all for deleted mailboxes? I don't see it in the documentation, you know maybe? Alternatively, could you ask someone if there should be a view of deleted mailboxes available for their delegation?
Thanks&Regards,
Kamil
Asking internally, though so far it doesn’t seem possible.
I’ll update once I hear more (or someone else will reply here).
