delete disklib
  • February 25, 2022
  • 889 views
Forum|alt.badge.img+5
Hello guys,
I'm having a problem, I'm trying to delete a disklib that gave problems in the DDB, but when trying to delete the disks it reports the error below, does anyone know how I can clean the jobs to delete the disks and disklib
Best answer by Mike Struening
@marcelo bernardes fernandes , do you have any WORM enablement in that library?  If so, you need to wait until the retention period has been met.
Forum|alt.badge.img+2
This error indicates that there is still data present on that library that has not been pruned off due to WORM protection enabled on one of the Storage Policy/Copies.  The WORM protection must be disabled before the associated data can be pruned off.
This is documented here:
-https://documentation.commvault.com/11.24/expert/13938_worm_copies.html
In order to disable the WORM protection, you will need to open a new ticket for that.  The Support engineer will review the issue with you and provide you a Waiver that will need to be signed by your management and then an auth code and script will be provided to disable WORM.
Hope that helps.
