difference in report timings
  • April 22, 2023
  • 86 views
we noticed difference in time from the  backup job summary reports which are generated from webconsole.
Commserve timings are in EST . Backup job summary reports from commcell console is in EST but same report from webconsole showing different timings. Please guide me on how to correct timings in  webconsole backup job summary reports.
Best answer by Damian Andre
Hi @bhargavi,
Which feature release are you on? I believe the WC report may be showing UTC timezone. There was a fix in FR28 that changes it to CS timezone.
  • April 24, 2023
Hi @bhargavi,
