Disable RMAN cross check globally, dataging
  • July 27, 2022
  • 309 views
Do we have any global setting or additional setting where we can disable the RMAN cross check globally for all Oracle instances. One of the infra I am working has bunch of Oracle instances and I am looking for an easy option instead of going to each instance and disabling it..
Best answer by Sunil
You may try this additional setting. When set to 0, it will skip cross check for all instances.
https://documentation.commvault.com/additionalsetting/details?name=%22ORACROSSCHECKTIMEOUT%22&id=632
Sunil-
Sunil
Forum|alt.badge.img+13
  • July 27, 2022
Sunil-
  • July 27, 2022
Thanks Sunil, I see from the link it supports 9 to 10 version.. Also I tried to find this in new version documentation couldn't locate it.. Does it support for version 11 ?
Sunil
  • July 27, 2022
I suppose it should. Can you try and confirm once? I haven’t used it for a while though.
Sunil-
  • July 27, 2022
I don't have this additional setting listed..
  • July 29, 2022
Hi Team, @Sunil Any lights on this please ?
Sunil
  • September 2, 2022
Hi @Prem
Sorry for the late response. I missed this somehow.
Can you manually type it in and see? It won’t show up in the dropdown but it should allow you to type in and save.
Sunil-
