Disaster Recovery Solution.
  • May 24, 2023
  • 111 views
Hi, I am doing some testing related to Disaster Recovery. i am new in Commvault I want to understand About periodic Classic replication , Periodic and Continuous replication. I didn't Understand how it work.
Anyone can help me to understand. This is Backup based replication or VMware to VMware based replication
I have some questions -
1. Periodic Classic - Is this Backup level replication? for this we need backup?
2. Periodic - Is it same as periodic classic? or it is Snapshot based Replication?
3. Continuous - For Continuous Replication Required Media agent. If we are using HSX then we need HSX both site source and DR site?
Best answer by Sebastien Merluzzi
@Rupankan Bhowmik ,
It’s all in the link I sent you, under Disaster Recovery and Replication  can you check.
https://documentation.commvault.com/2022e/essential/129536_component_requirements_for_primary_and_secondary_sites.html
https://documentation.commvault.com/2022e/essential/129967_replication_for_databases.html
Sebastien
Hi @Rupankan Bhowmik
This is the link you need:
https://documentation.commvault.com/2022e/essential/113647_disaster_recovery_and_replication.html
Also, you can watch this video: Periodic VM Replication for All Hypervisors
https://documentation.commvault.com/search?q=periodic&oem=commvault&majorVersion=11&minorVersion=28&site=expert#q=periodic&t=All&sort=relevancy
Let me know if you have any questions.
Sebastien
Hi @Sebastien Merluzzi
Thanks for Reply
I have some questions.
What are the recommended system requirements for performing periodic replication?
What are the recommended system requirements for performing periodic (Classic) replication?
How can I use replication for Database, Large Files and Big Data?
for this scenario Working same as Periodic Classic?
For This I read Documents but not understanding flow.
Can anyone provide details about RP store?
For RP store Which Type storage we need?
disk/Hyperscale or both can we use?
