Discovered VM's after backup
  • February 28, 2023
  • 142 views
Every day, after backups, VM machines are discovered that are not used for backup and do not have agents installed. Removing them from "client compters" doesn't help. VMs have never been used for backup. I ran tests on another environment and after removing the VM this situation did not occur.
Commvault version is 11.24.90. The situation was the same before the upgrade.
Is there a way to turn off auto discovery from vcenter?
Best answer by kago
Setting “Refresh Datacenters” from the instance level - unchecking the option helped.
Forum|alt.badge.img+18
  • February 28, 2023
Can you tell me if the subclient content is set to “/” or do you have individual VMs listed?
  • March 1, 2023
I have individual VMs listed.  Additionally, in Backup Set Property of defaultBackupSet I have filtered unused vm.
chrisknows
Explorer
  • March 2, 2023
Thats why. The vms have to be discovered to be filtered.
rather than filtering out unknown vms tighten up your discovery rules.
you can’t really get around the order of the logic.
filtering happens post discovery in a way.
  • March 2, 2023
Unfortunately removing VM’s from the filter didn't help. VM’s are still being discovered.
  • May 21, 2024
