DR backup to Blob hot - azure
  • May 30, 2024 7:10 AM UTC
  • 72 views
Forum|alt.badge.img+8
Hello
I need  to back up the DR backup
of the CS to the cloud in Azure
And I can't find which addresses should be open in the firewall and which ports
This is the document I found:
https://documentation.commvault.com/2022e/essential/configuring_cloud_library_as_export_destination_for_disaster_recovery_dr_backups.html
Thank you very much.
Forum|alt.badge.img+2
  • May 30, 2024 2:44 PM UTC
Hello @ariel_b
We use HTTPS to interact with Cloud Storage so you would need 443 open between the MediaAgent and storage vendor.
Thank you,
Collin
