edit reports results in sad face
  • February 26, 2026
  • 7 replies
  • 147 views
downhill
Explorer
Literally -
So did I miss some release notes that editing reports is no longer a thing? I have more than one CommCell doing this and I only noticed it when our backup summary reports suddently turned to “garbage” with essentially no content.
11.40.34
thanks
I see I am late to the discussion in the Report builder thread. You guys have no idea how frustrating this is. OR, maybe you do by the looks of that other thread?
Best answer by Pradeep
Hi ​@downhill ,
The Reports Builder feature is not available by default in SP40 command center. It can be accessed only by installing the add-on Web Console package, which is available upon request.
Note: The Web Console package has been officially retired and is no longer maintained. We strongly recommend against installing or using it in any production environment. However, if you choose to install it—for example, to access functionality like the Report Builder—it must be deployed within a fully isolated network that has no access to sensitive data or internet connectivity. This is a critical security precaution, as the retired package may contain unpatched vulnerabilities and is no longer supported with updates or fixes.
Additionally, we are working on introducing the Report Builder in the next feature release, which will be available by default in the Command Center.
Link to download the package https://cloud.commvault.com/commandcenter/#/softwareStore?catId=96&keyword=webconsole
https://documentation.commvault.com/11.40/software/building_and_deploying_reports.html
  • March 2, 2026
Hi ​@downhill ,
Forum|alt.badge.img+9
  • March 4, 2026
Hi ​@Pradeep,
Its good to hear that you are planning to introduce the reportbuilder in the next feature release. As this is a missed feature.
But what does that mean, which LTS will it be targeted for?
The june 26 release or the june 27 release?
  • March 7, 2026
Hi ​@John Robert ,
As of now I am not sure if it will be part of June release. However, we will try and share more details on the release info here.
  • June 16, 2026
@Pradeep Any news about this?
From the documentation, it looks like it did not make the cut for 11.44?
So that means it will be unavailable for another year as we are only running LTS?
Scott Moseman
Forum|alt.badge.img+23
Report Builder is included in 11.44.
Scott
  • June 16, 2026
I’m happy to hear this.
Documentation should probably be updated with this as well.
  • June 23, 2026
With SP42.110 command center has been enhanced and edit option are availaible.
