Effect of worm storage lock on disk after activation.
  • Oct 26, 2024 2:54 PM UTC
  • 71 views
Hi everyone,
What impact will enabling WORM Storage Lock with full proof have on disk space before and after its activation?
Thanks.
Best answer by Mohamed Ramadan
hello @Nabin
Before no impact on disk space after doesn't directly consume additional disk space but it may Impact ob Dedup process If data is locked, it may not be eligible for deduplication with other data, leading to increased
deduplication can be applied to data before it's made WORM once data is WORM-locked, it can no longer be deduplicated with other data this can lead to increased storage consumption
Mohamed Ramadan
Data Protection Specialist
Mohamed Ramadan
Explorer
hello @Nabin
Mohamed Ramadan
Scott Moseman
Forum|alt.badge.img+23
Whatever your storage usage is for your retention, assume you’ll need 3x.
Scott
