Enable ransomware protection
  • February 1, 2021
  • 623 views
neuwiesener
Explorer
https://documentation.commvault.com/commvault/v11/article?p=7877_1.htm I was wondering what this fix is about that can be downloaded from https://cloud.commvault.com/webconsole/softwarestore/store.do#!/147/0/15365 . Is this to be able to see the check box on the media agent or is this a report. If it is a report is can someone please share a sample output of it please?
Best answer by MFasulo
The package is the report and workflow to enable this ransomware protection across the estate.  It provides the 1 button to enable, so you dont need to check the box manually on all the MAs if its not already enabled.
Forum|alt.badge.img+2
The report is used to enable the Ransoware protection function.
Report
MFasulo
  • February 1, 2021
neuwiesener
Explorer
  • February 1, 2021
thank you guys!
